"Shop manual on order but I
"Shop manual on order but I'm snowed in and want to fiddle with my broken motor. I picked up the boat with blown motor as a winter project. Lower piston has about 1/4" in/out movement but only thing apparent after pulling head is a light scratch in the affected cylinder (& piston movement). Top two cylinders in great shape but cross hatch less visible in lower (affected) bore. I'm suspecting bearing went out but can't tell if the slop is from the lower or upper end of rod. I'm anxious to pull the powerhead and dissasemble to see damage, but reluctant to try without manual. How about the rod that is attached under the carbs that go through the middle section? Any quick tips that will get me going, other than the sensible one (wait for the manual?"
