C
claudiusdrusus
Guest
" Dear Joe and Sparky,
Than
Thank you so so much for your help thus far. I am really in a tight way with this mechanic. Here is a summary of what happened taking into account your other advice:
1. Engine: 200 H.P Mariner 1991 6 cylinder
2. March 1st: Engine running normally then dies. Power head crack by piston 4 and piston destroyed.
3. Mechanic replaces powerhead, completely cleans carbs, new carb kits., filters etc.2 pistons and gaskets.
4. March 24: 2.5 hours of engine running time after repair job engine suddenly dies.
5. Powerhead by piston number 2 (same side) is shattered, cylinder dry (says mechanic no fuel or oil to piston) sleeve and block damage.
6. Mechanic says this indicates blocked carb number 1. The reason is dirt in the fuel tank. He is insistent on it and says it is not his fault.
Why do you think my powerhead on the same side as the last explosion (piston 4) exploded (piston 2)?
The mechanic says he completely cleaned the filters and carbs and yet 2 hours of run time later - boom.
Please, please help. I am at wits end with this and not sure if I should sue or what. "
Than
