Help.need to replace the hydraulic trim hose from pump to manifold.c. Can it be done by fishing through
transom
or does eng need to be removed,,, if so should you pull line out through the trim manifold side or pull through into the engine side...because of fitting ends being bent more on manifold side I would think it would be best to pull through then back in. Any attemp this yet
transom
