I am having a intermit proble
I am having a intermit problem with the power trim not working on my motor - 1987 merc 135hp when trimmimg up only. It will always trim down but trimming up at times it will not work. If it does not trim up I can trim it down a little and then it will trim up. At times I will have to trim it down a few times before it will trim up. Other times it will trim up just fine on the first try. I was thinking it may be a bad connection in the switch. Only problem is I can't seem to figure out how to get at the switch. The control is a single quick silver with the trim control being on the end of the throttle control on the inside. Can someone give me some help?
