Power trim loss under load
Saeulfr
Hey all,
I need some help. My 2020 Mercury 75 hp trim will not hold under load. I can trim it all the way up at idle but as soon as I throttle up it lowers. I figured I'm losing pressure from bad seals so I ordered new seals and removed the piston from the trim assembly cylinder. However, I cannot remove the bottom cylinder that looks as if it just screws off. I do see a pin of some kind but I'm not sure if that needs to be removed or even how.
