Power trim leaks down on 135 v6
big_builder
"Hello,
My trim leaks down
"Hello,
My trim leaks down on my merc 135 v-6. Whether it's parked or when I am drving. It will leak down in a matter of minutes when driving. There is no fluid leak. What can be the cause of this? I am hoping I don't have to rip the whole unit apart.
Thanks"
"OK Bandit,
What do I need
"OK Bandit,
What do I need to do to fix the problem?
Sorry but I have never even had a trim unit apart before.
Thanks"
"Bandit,
I have had a ram a
"Bandit,
I have had a ram aprat before, on my johnson, once apart and assuming I find the check ball what will I do with it? replace or clean etc?
Thanks"
"Ok, I will rip apart this we
"Ok, I will rip apart this weekend. To remove the manual release valve do I pop of the c-clip and unscrew right out?
Thanks for all your help so far!"
So I took out the check valve
So I took out the check valve and cleaned and nothing changed. I then took out the manual release and cleaned and nothing improved.
Does anyone have any suggestions about why my power trim leaks down?
"Bandit,
I just noticed you
"Bandit,
I just noticed your o-ring comment. Should I order new o-rings for it? Is the best source a mercury dealer for this?
Thanks again."
