Power trim for a 1989 evinrude xp 150
spicerak
ok this is what happens the tr
ok this is what happens the trim up and down work fine from switch in back but the one in front just makes a clicking nose in the relay box there are 2 relays and i have played with them and some times it will work but not for long what should i do is it the relay for the front thanks
i would start with checking fo
i would start with checking for bad wires or bad connections.....run an ohm test on the switch as well as the wires.
does it work when you play with the relays or just works whenever it wants to?
well when i take them apart an
well when i take them apart and then put them back in it will work for a little bit and than it stops do u think it could be the relay should i spray electic cleaner in them maybe corrosion
