I have a general question about the power tilt on a 1994 Force 90 hp. motor, mounted on a 1993 Spectrum 18 foot boat.
It seems that the power trim does not always work. The switch seems dead at times, and then it works at other times. This has caused major problems at the ramp when I could not raise the motor to pull out. One time I had to jack up the motor to relieve pressure to make the trim work. I don't know if it is the switch or the trim motor. I would appreciate any help you can offer. Thanks. One more question...Same boat, how do you remove the throttle handle assembly from the boat when it has no visible screws? I am at my wits end with this thing. Thanks again.
