My 1999 50HP Johnson's power trim and tilt will only tilt up if I assist it with armstrong...mine
Then it will not stay in the up position....the motor runs great and tries to lift the motor and will do so somewhat......
Fluid level is full....bypass valve is set to the optimal setting......
Question...1) Can I replace the 'O' ring/s in the piston
2) Can I achieve positive results by replacing the hyd fluid with a heaver grade
3) Replace the whole unit
Thank you in advance
Mick
Living the American Dream on Anna Maria Island FL
Mick
