I have a 2002 Nissan 30 HP. The upper seal on the power tilt cylinder leaks and appears to not be a replaceable part, but the cylinder appears to be screwed onto the base. The 2005 Tohatsu 30 HP shows the power tilt as an assembly that has replaceable seals.
Does anyone know: 1) If the 2002 power tilt cylinder will unscrew from the base, and 2) If the 2005 cylinder assembly fit into the 2002 power tilt assembly base?
Thank You
Thank You
