| power tilt stopped suddenly on the port outboard as it was being raised, also no response at port ignition switch. Starboard outboard and ignition switch ok | |||||||||
| was already to replace #3 10a fuse, but it wasn't blown. Using an ohm meter, all 6 fuses plus the 150 amp fuse checked okay using a volt meter, there was no voltage at the #3 fuse contacts (fuse out). I grounded the meter at the battery. Ran a direct, 10a fused line from the positive battery post to the #3 fuse contacts, again the fuse was out. Did not run a negative wire this time, let the harness do that job.
