Power tilt and trim probs
R
rjnitro101
Guest
"a sudden surge in the volt me
"a sudden surge in the volt meter to 18 and the a few minutes later while boating, the motor starts triming up all the way, shut it off and had to unhook the battery to stop the trim motor, i thought i narrowed it down to the trim switch on the control, replaced and worked great then about 30 min later, came out of the house and the motor was triming up and still going,for approx 30 min i would guess what would cause the trim switch to suddenly override, and solutions and possible fixes would be good"
"find the trim relays, the thi
"find the trim relays, the things that go click when you push the switch, swap up relay for down. If it now auto trims the other way the relay is bad"
where would the trim relays be
where would the trim relays be located? any quick ideas
"looks like part #29 in the fi
"looks like part #29 in the first option, trim package.
due you have the trim switch on the engine also"
"i have the trim switch on the
"i have the trim switch on the engine,the front and the throttle"
"with trim switches in 3 locat
"with trim switches in 3 locations, it could be a bad switch anywhere or the wiring going to them. It could also be the relay, thats why I said switch the relays, easy and free.
If a relay just clicks and the trim pump doesn't move, the relay is bad, the pump is shot, or the wires going to the pump is bad. Your battery is still good right."
"just charging the battery ful
"just charging the battery fully again, when the problem first started, i narrowed it down to the throttle switch,unpluged all switches and rear and front worked proper, when i plugged in the control one it was auto going up,replaced it and worked fine,then all of a sudden it started working on its own, going to start with the relay and go from there, what do you think"
"when it powered on itself i w
"when it powered on itself i went outside and the pump was still working but was very hot,could have been on for 30 min. duh! now all switches just click at the relay,"
"swap relays, if it goes auto
"swap relays, if it goes auto down its a relay. disconect other switches but the throttle, if it goes auto up its bad wires in throttle"
"thanks for all the help, i wi
"thanks for all the help, i will full charge and try it out, and let you know"
"swapped relays and both of ju
"swapped relays and both of just click,up and down
from all switches????"
"if the relays just click, che
"if the relays just click, check for power at the pump, it might have burned the pump up while you were drinking a cold one. Original problem still exists though"
"i just checked the trim motor
"i just checked the trim motor, i hooked up a battery charger to the ground and the positive and no movement from the trim motor at all, im thinkin that it is kaput, what do u think."
