"Hello i have a Sea Ray with t
"Hello i have a Sea Ray with twin 350 mercruisers late 80's both have been great all serviced, risers,manifolds,shift cables everything as we have gone. Now i have power loss on 1 motor it started at 1800 RPM and would go no further so called mechanics and they removed carbi and said yep dirty and all that so they put a new kit through it and cleaned it all.They put it back and off we went strait to 3100 RPM and same problem shuts down unless you back off then its fine.I called them and they removed it and did more then tried again. No good then again then again,800 dolla later no different! What do i do now? If you pump throttle 5 or so times at 3100RPM fast then flatten it she will go to full throttle and stay there just fine.All ignition fine no back fire comp all test fine,Done filters they have done this and that to carbie,Not sure where to turn from here.I guess they just have no idea!!What can i try and check myself,i feel im getting no where and im very frustrated. H E L P Please!!!!!!!!!!!!"
