gastite101
I changed everything in the fuel side per my last topic. (re: Port engine running rough)
New fuel, new filters. I took the boat out and the Port engine still runs rough. It started up good and in neutral it sounded good. When I stick the Port engine into gear it runs rough and I smell gas again in the exhaust but not as bad as my first listing. I ramp the engines up to speed and for some reason the Port engine would not go over 2500 rpm’s. It just felt like something was holding it back. Gas smell was still around and I also noticed when I was doing 2500 with both engines and doing about 16-17 knots the Port engine had a lot of steam coming out the exhaust, more then the Starboard side.
I checked the engine oil to see if there was water and that was ok. I checked the tranny and that was fine.
I had a couple of possibilities it might be but could use your help:
1) Could a bad battery help in losing power? I have 1 battery for the Port engine only.
2) could it be the carb? Might need it rebuild kit and cleaning
I will say that the boat ran well and the port engine did not give me the same trouble as the first topic (port engine running rough) it stayed at 650-700 rpm’s at Idle unlike last time. I did notice more fuel was being used on the port side. I was doing 2500 rpms on both engines and the fuel meter on the port side showed 16 gallons per hour where the starboard was at 10 per hour. I don’t know if that tells you anything or not.
Thanks for your help team.
