Model:E155WTLCRS 1984 155 hp. The gasket is weeping and I was told by the previous owner that the bolts need to be tightened every so often. Is this gasket under engine pressure. Is pulling the power head and replacing the gasket a monumental task for the moderately skilled mechanic? It appears that it is the fuel mix that maybe leaking. Also, are the bolts for this assembly prone to breaking? Thanks in advance for the reply.
