am_dew
Advanced Contributor
Has anyone ever installed a filter of some kind after the water pump on a raw water cooled engine? The impeller in my water pump for my AQ130C engine failed a few years ago and I had to remove the oil cooler and the cooling tube leading to the cooler to find the broken impeller pieces, and then put it all back together, replacing seals. Seems a filter after the pump would be a good idea to avoid doing all that and could be easily checked for blockage as a normal maintenance item. Or would the flow out of the pump and eventually to the engine be adversely affected? Thanks for any comments or suggestions!
