optsyeagle
"I took my motor out of the la
"I took my motor out of the lake for winter storage this weekend. I was inspecting the outside of it and noticed that inside the water exit holes just above the cavitation plate is a small piece of black rubber material.
I am guessing that this may be part of an impeller fin but I am not sure.
My questions are this:
1) Could pieces of an impeller fin make it that far through the water circulation system or is it more likely that this is some other piece of the cooling system?
2) I acquired this engine this year and do not know when the impeller was last changed. Would you change the impeller alone or do a water pump rebuild with one of the kits.
3) Would it be best to wait and do this work in the spring just before I put it in the water or does it matter if this new impeller/water pump sits in winter storage for 6 months or so?
4) How is the best way to get this material out of the water circulation system?
The engine never overheated. When I was running it to spray some engine fog into it, I felt the engine head just after it shut off and was just barely touchable as it usually was. I really appreciate any help I can get. I have never changed a water pump before."
