fishinhard
165 HP 250ci. Rebuilt the engine, had the carb rebuilt and tuned for that engine. HEI dist, new everything for the most part. Set the timing at 6 deg BTC. Runs great on the trailer. Put it in the water, starts and runs perfect. Goes into gear perfect and will start to rev up. Get to WOT and it boggs down. If I back off just slightly it does ok. I advanced the timing a little and it got better. Ran it again and advanced at little more. Then the pinging started so I retarded just a little. It is not even getting on a full plain. I hooked up a vacuum advance to the manifold before doing this timing. Before that it would not go more than half throttle if I was lucky.
So is it a timing issue or does the carb need to be adjusted. I thought the adjustment screws were for idle mainly. Please help. I have soo much time an money wrapped up on this engine..
