hi guys i have a 1982 johnson 90 hr motor. it seems like the primer soleniod may be bad. i checked the ohms on the actual soliniod and from what the "seloc book" says is its in the right range. when i took off the discharge fuel lines off it and pushed in the key no gas came out. then when i turned the red nob on the soleniod gas came out. the weird thing is i put it in the water and i had a hard time starting it. and we broke down out on the water. then when i came home i check the primer soleniod and tried starting it again of course with water hooked up to it. it fired right up! so now im completely lost on what it mite be. im not sure if the primer soleniod is good or bad. or if i have another problem... someone please help!!
thanks alot guys!
Gus
thanks alot guys!
Gus
