warrenthepilot
"Hi everyone. This is my first
"Hi everyone. This is my first try at this forum....I'm not a mechanic, but I think I'm a pretty good "screw turner", with "passable" analytical skills.
My 1983 Carver Riviera has twin 305/220 Crusaders. Both engines have their individual 75 gallon fuel tanks, but I can cross feed as necessary to balance the load. Both engines are original with 1200 hours on each.
Here's the problem.
After launching for the season port engine has been running very rough. Won't idle below 1000rpm. Exhaust reaks of gas, and a nice pool of what appears to be unburned (read wasted) fuel forms a 10 foot diameter slick on the surface after a mear 3-4 minute run-up.
Carb (stock Rochester) and stock distributor were rebuilt in fall of 2007, but only about 5 hours on them since,as boat sat at the dock most of 2008 due to family commitments.
Since I dock the boat "port side out", the port fuel tank is the harder one to refill,so I tend to use that tank as a reserve for most situations. Consequently the fuel in the port tank probable dates back to spring of 08, whereas starboard tank was a fresh fillup prior to last October's haulout. Stabilizer was added to both tanks at haulout.
When I started the engines this season, each was fed from their respective individual fuel tanks. At first I thought the problem was stale fuel,or water in the fuel, so after the first couple of runups, I switched to the newer fuel in the starboard tank since the starboard engine was running just fine. After the switch, the engine seemed a bit smoother , but non the less still quite rough at 1200rpm, and then complete stall at anything less than 1000 rpm.
Here's the basic stuff I've done so far:
1) I checked the filter canister on the rear of the block and yes, there was about a thimble full of water in the bottom....but I didn't think that small amount would continue to cause such continued rough running. I cleaned it and replaced it.
2) I checked all plug wires for firmness of fit at each end.
3) I removed and inspected each spark plug. Every plug had a slight coating of black carbon dust, but EVERY plug was soaked with gasoline. This suggested to me that there must be a common denominator if all cylinders were the same. Is my carburetor running too rich? Has the water in the initial startup fuel somehow screwed up my new carb?
4) I attempted to double check my timing....perhaps I knocked the distributor out of alignment while readying the boat for launch? When I hooked up my strobe, it wouldn't register on #1 cylinder like it normally should. I found this odd, so double checked that the light was ok by testing it on the good engine....it worked just fine. My strobe has an "induction type connector" that just has to encircle the plug wire rather than having to disconnect it....I tested each plug wire on the good engine , just to see if the current in each wire would set off the strobe, and each as expected did just that.
I then followed the same procedure on the sick engine and surprise.....while idling at 1200rpm, only 2 spark plug wires activated the strobe!!!! Did this mean I only have TWO cylinders Firing????????? I then proceded to individually remove the plug wires, one at a time, to see if there was any change to the idling engine. There was NO change in engine roughness when each of the 6 "dead" plug wires were removed and replaced. The only 2 that caused the engine to quit as soon as they were disconnected were the same two that activated my strobe light.
GEEEEEEZ........now it sounds like I have a electrical problem as well, if only 2 cylinders are firing????? I checked the inside of the distributor cap....some light copper discoloration on each of the pins...so I just emerypapered each one to be sure.....replaced it and started the engine again, but no change?????
Ok so this is the part where I "CRY UNCLE". Any and all help and advice would be most appreciated.
Thank you in advance
Warren - Toronto,Canada"
Here's the problem.
