Hi guys,
This is on my '76 Crusader 220's, FWC half-system. Having this problem at cruising above 2500 RPM. The port engine (counter-rotating) gets up to 190 degrees while the starboard engine stays at 160. When I bring it down to 1800 RPM or lower the port side will cool back down to 160 within 5 minutes. I just pulled the raw water pump and checked all the hoses, and things look fine as does the impeller. What should I look at next... or is 190 not all that hot?
