Port Engine Ready to Test Run
bob_on_this
"All Ready to run.
[IMG][ur
"All Ready to run.
url]
url]
url]
url]
url]
"Bob:
All you need to do is
"Bob:
All you need to do is add a couple chairs to the front of the trailer and.....
Seriously - Damn Fine Job!!!!!
One recommendation - hate to be the one to do this but - Remove the raw water pump belt and relocate the "garden hose adapter" so it flows ito the cooler. In essence, this will bypass your raw water pump which is necessary.
What are those exhaust pipes made of?
You see, the first thing you'll want to do is raise the RPMs (Cam break-in, right?!). This will make that freshened up water pump suck its feeder hose flat. As they say, from this point on the rest could be history......."
"Mark, Thanks for the RW pump
"Mark, Thanks for the RW pump tip, I had not thought of that. I will get that done. This is why I post on this site.
The pipe is just some thin wall 4" pipe we had at work.
Bob"
"Bob, I wonder what the neighb
"Bob, I wonder what the neighbors must think? A little too much Tim Allen Home Improvement maybe?
The uninformed might think you are trying some weird conversion. Nice JOB"
"Come on Al, it would make a h
"Come on Al, it would make a helluva dune buggy, especially with flames coming out those 4" tubes!"
"Slick setup, but remember not
"Slick setup, but remember not to rev it too high since your garden hose flow can't keep up with the raw water pump.
When I pre-tested mine, I removed the belt from the raw water pump and shot the water directly into the motor. Safer that way and, in winter time, there's no way you will overheat it.
Jeff"
"Bob, what work have you done
"Bob, what work have you done on these? I've read over some of the older posts but did not see where you started."
"Joel,
Complete OH. New pisto
"Joel,
Complete OH. New pistons, rods, cams, followers,
oil pumps, valves, springs, guides, seats.
Both Transmissions where OH as well.
I rebuilt the RW pumps, starters, alternators, carbs.
Installed new coolers, drive couplers and complete exhaust manifolds. (Changed over to Center style)."
