Port Engine Cutting out
jayj123
I have 1985 model 270 Crusaders. The problem is at 2800 rpms, the port engine cuts out and drops to about 22 - 2300 and runs rough. This appears to be the point where the secondaries begin to open. Once I throttle back a little I can get back to 2800. The engine ran fine up to 3400 rpm the last time I ran it. Also, it appears to be running fine up to 2800 as I ran all day on both engines and had the same fuel burn for both. Any Ideas???
Doubt your secondaries are open below 3000 rpm.
If the fuel burn is consistent, I'd guess the ignition is fine and the issue is with a fuel restriction - valve not open, filter clogged, filter not seated well and leaking air....anti-syphon valves know to restrict fuel flow, too.
