hello, I have checked the plugs. they are fine. switched them and it still happens in the third carb. while the motor was running took a light tester and stuck it in the coil wire against the plug and the popping sound stops completely and the motor runs fine. Take it out and runs rough and pops again. I have pulled the plug wire off while running and motor does not bogg down like other two do. There is deffinately spark in the wire saw it good when using the tester and got a hell of jolt when not using pliers to pull the wire off. haha. dummy. i switched coils from third to second. popping sound was still there but not as bad. looked in at reeds and couldnt see anything bad all looked fine. If this is a stuck vavle, how would i fix this. Thanks
