I have a 1989 merc 135 V6 that has been giving me fits. Owned it since new and no problems EVER other then maintenance. I'm guessing it is running on five cylinders. It will not idle and will barely put a 19 ft sea ray on plane. If you put it to WOT it will skip a bit less until it starts running good. Seems like a fouled plug. If you run it full throttle for several minutes it continues to run fine but as soon as you pull it back off full it seems to miss again. The boat ran great the first trip out and the second trip this started to happen. New gas this year ad no change from first and second trip. I brought it home and replace the normal stuff, plugs, water separator, fuel filter but everything looked good. No change in performance. I figured it must be crap in the carbs so I pulled all 3 down to nothing. They were perfect, not so much as a spec of crap anywhere and the fuel showed no signs of water. I measured all the coil packs and not sure what they should be but all pretty similar. Checked all the lines and all looks good. Compression all between 114 and 116. I am simply at a loss. I should also add that this was converted last year to pre-mix and is running merc oil at 50-1. Simply not sure what else to try. Only thing left is CDI box but guessing this is not cheap to simply try. Any elp would sure be appreciated. Thanks in advance!!
