"What should a Chevy 4.3L Vort
"What should a Chevy 4.3L Vortex get for fuel economy? This motor is attached to a Cobra Stern drive and pushes my 21' Bayliner (a Full Cabin) which I run entirely in the ocean. I've had lots of issues with this motor and replaced the distributor and carburetor last spring.
I've attempted to check the fuel consumption twice by filling the tank up, going out for a few hours, running the boat on step (25mph @ 2600 RPM ) and then filling it again after the trip and doing the math. I'm coming up with 1.2 to 2.2 miles per gallon.
I think this is lousy mileage but have nothing to compare it too. Also, I believe I have related issues
-First: The motor is difficult to start when cold and won't remain at idle until the motor is warmed (usually I warm the motor at 1200 RPM for approximately 10 minutes). This “troubled idle issue” goes away after the motor is warm and will then idle at approx 600 RPM for the rest of the day without further problem.
-Second: If I run the boat at power for a while and then pull it back to idle and shut the motor off, I get lots of “Run-on” and the motor will not turn off. HOWEVER, if I idle the motor for a few minutes (usually 3 to 5 minutes) to cool it down, the motor shuts off just fine.
My exhaust smoke seems normal (no blue or dark smoke) however, when I run the motor with a garden hose and water muffs on the stern drive, I get soot on the ground from the exhausty water. I’m under the impression that this is normal as I’ve had 4 stroke outboards which did the same thing.
What could be the problem?"
