Pointless Ignition Upgrade
Eddie327
I have a Johnson 85ESL69S and is all original. I ran across this and was just curious about if it is a good upgrade or the points system is just as good or better. I had always read and heard there was not a pointless upgrade for these motors but this looks to be one but not sure since I have never seen another one. Prestolite 12D 4286
Does your crankshaft have a hole ( 3/16" ) for a pin.-------Needed to locate that metal rotor.-------That system would be off a 1969 model 115 HP or off a 1970 model ,or off a 1972 model 125 HP.
As I recall mine does not have that ring with the 4 square shoulders because I remember watching a video a little while back seems like on a Johnson 115 and he removed that ring and I thought then I don't remember removing that on mine last time I was in it. The listing for sale reads as: JOHNSON EVINRUDE POINTLESS IGNITION UPGRADE COMPLETE SYSTEM 85 100 115 150HP. It will work with V4 Johnson Evinrude 1968-72 point type ignition system. I noticed that included my motor but had also noticed that ring you refer to so that made me question it no doubt. So no doubt that will not fit my 69 model Johnson 85. That was my reason in asking because people will list things not knowing as you can see above it plainly says it will work on mine.
Without going in there to refresh my memory, I'd say your motor has a cam profile ground on the crankshaft to operate the points. The breakerless system has a round crankshaft in that area, for the sensor ring. In other words, no go.
Which system is better? Frankly, I would have a hard time picking one over the other. Both were state of the art for their day, but both were troublesome in my book.
That metal ring is the rotor for the sensor.----Not used on the breaker point motors.----Does your crankshaft have the hole to locate that ring , yes or no ?----And that system is definitely not used on a 150 HP model as there never was a 150 that used it !!
No need to look at the pictures.----Have a few of those systems laying around.----For $300 I would want the whole motor.-----Likely get motors like that for $100 or less at my supplier.
