Point setting OMC
fireman
Can anyone tell me the points
Can anyone tell me the points Gap setting on a 1988 OMC Cobra 5.7 and is there any tricks to setting them I should know.Thanks
"Point gap is .017, I prefer t
"Point gap is .017, I prefer to use a dwell meter to really set them though and that should be between 27-31 deg. Your idle RPM (in gear) should be betwen 500-600. After you set the points then you should check/adjust the timing at 10 deg BTDC."
"I set my initial point gap to
"I set my initial point gap to .017 ", but I had to open them up quite a bit to attain 30 deg dwell. Is this common? How much gap is too much? I think I end up at around .020 ".
The engine (in my case an '89 4.3) seems to start, idle, run just fine. It has been this way since I got the boat (about 5 years). Should I be worried about a distributor problem?"
