In my opinion,
The bravo II uses a much bigger diameter prop, thus has more thrust (if you will) and I also believe that your mileage and speed would be improved with this set up.
Back in the day of 1981 when this boat was biult, they would have used the TRS outdrive wich is the predissesor to the Bravo drive. The TRS is a very large outdrive and wieghs a ton!! BUt it would move a large boat due to prop size.........
Either way you decide to go do some more research and look closely at the bravo II,
7000 lbs and only 320 hp, = bad mpg's and slow speeds.......A boat that size and wieght really should have twin 320 hp, inboards............actually diesel inboards would be best!!
