freddie1944
I bought a 1969 18 horse Evinrude, model number 18902d. I have done everything I know how to do to fix this problem. It starts and runs at low rpm. But when I give it throttle it dies. Unless I can get it back to idle soon enough. It dies when the roller hits the cam and starts to move the arm that goes to the carb.
I have put in new coils, points,condensers, plugs and plug wires. When the boat motor mechanic pulled the bottom off the bowl of the carb.He said that there should have been a gasket over the center tube. He put one on the tube and he put in a new needle because. The one that was in there, did not have a groove in it for the spring to hook on to pull the needle back down. It seems to run fine in a barrel. But dies in the lake when I give it throttle. Any and all help will be very much appreciated. thank you
