Hello I have a 1984 35 hp mercury I can’t get it to start at all!! Even with dumping mixed fuel in the carb while cranking and even tried starting fluid but only couple short bursts. I have spark on both plugs good spark brand new battery I have 137psi and 134psi on compression brand new fuel pump kit new float and adjusted taken apart twice and cleaned thoroughly. Even while dumping fuel in the face of carb while cranking the spark plugs are still dry. Is this reed failure?
