D
dtacmed
Guest
I have a couple of Questions
I have a couple of Questions concerning a motor I recently bought. Its a 40 yamaha 88 model. 1st when running at full throttle its showing almost 16 volts on the meter almost pegged when I slow down or cut on lights etc it drops is this normal or is it putting out too much voltage. 2nd where is the water supposed to exit from the motor. I removed the cowling and there is a small fitting where it looks like it should exit nothing hooked to it. With a motor flusher hooked up water is coming out the exhaust and the smaller port near the cowl. It does not appear to be running hot at all even after running alot. Please help thanks
