Please Help temperature range vovlo 21
Hi I was wonder does anybody k
Hi I was wonder does anybody know the right temperature range for a Volvo 2.1 (1985) My was around 210 going @ 25 mph I was thinking that was a little high... ????????? Thanks
"One reason could be that the
"One reason could be that the gauge is misreading due to a fault in the sender or the gauge itself. Moreover, many gauges are not precisely what we could call 'highly accurate instruments'. One thing you can do is verify with an infrared thermometer that the temperature gauge is reading correctly; anf if the readingis correct, then you will have to find why the temperature is higher than it should. Check this to find the most common reasons for high coolant temperature:
http://www.marineengine.com/discus/messages/12487/85849.shtml"
