I desperately need some help. I have an 18 ft Bayliner with the above mentioned motor. Been trying to get er back working.At first wouldnt crank at all. Replaced starter. We are starting now, and are running on muffs. So I put it in the water, wont start. WTF.Back in the driveway starts, and runs like a champ. Pull the carb take it apart, clean the bejeezus out of it, put it back in. Starts right up. again. No surprise there. While its out, change oil, gear oil, spark plugs because why not. Still starting great. Get back into the water. Starts right up. Hot diggity daffodil we may be onto something.Throttle I rev up to see how it does. No problems. Starting to look up. Seas are a little rough for a sea trial because if I break down Im likely to capsize. Head back out couple days later, lake is like glass. In the water at the launch. Starts right up again. Looking good. Throttles up again. Looking better.Time to go out. Putting around no problems. Throttling up progressively no problems. I get up to about 60% full throttle and start losing power. Throttle to neutral immediately. Engine dies. Wont restart. Turn the key, starter engages, tries to turn over cant.Go to engine compartment. Oil everywhere. Check the dipstick, completely empty. Oil filter is about 1 inch unscrewed. I tightened oil filter snugly im sure of it, also have run it significantly since changing oil. Whatever, one problem at a time. So im literally dead in the water. Back in the driveway (thank god for sea tow) on muffs, refilled oil, same symptoms. Starter engages, tries to turn over, wont. seems locked up. So question is, am I completely effed or is there something else I can do?
Thanks in advance
Jonathan
Thanks in advance
Jonathan
