please help leaking carburetor
Joey412
Hey guys I have a 120 force l drive and having a car b issue I replaced the needle tried to get the seats and I'm told
There obselete I cleaned the carbs spotless set the floats but they leak through the vents and throats. Any ideas
I'm using a external tank with the ball could that. Be to much pressure can the fuel pump be bad
Thanks for your help
Always include the Year, Model, Serial#s. They made a whole bunch of different motors with a lot of little changes. Usually the carbs can be cleaned nd the original parts can be used. You might have to tweek the tabs on the floats to make them work. You have the manual? The factory is best, Clymer then Seloc. The float should be level when turned upside down. The fuel pump if it's making the carbs leak?? it should be good. This pump is a low pressure pump and it won't be strong enough to do that.
