"Ok so here is my problem. Hav
"Ok so here is my problem. Have a 1990 omc 4.3 liter in a sunbird boat. The engine was replaced before i bought it and they used a newer model block not machined for manual fuel pump. They put an electric fuel pump on it. The problem is my boat mechanic says that it wont work. The boat runs fine right now and i can see the risk of the electric pump, but if it is set at the right pressure will it be ok. Also what type of pressure should it be set at. Has a 2barrel rochester on it. Any ideas of what to do would be greatly appreciated. THANKS GUYS!!! UR THE BEST"
