My 99 johnson 115pleem has been running worse and worse lately. It started where it would just start sputtering every now and then, then it got worse and worse. When it starts acting up we will go from cruising at 4300 rpms to it breaking up and spitting and running horrible and not go above 3000 or so. It will some times rev back up for a second like nothings wrong then rite back at it again. This started happening for a minute or two at a time now its getting worse and worse. last two times i took it out it started doing it 1 minute after i left the dock i kept running it last time and it eventually stopped breaking up and ran good again on my way back. today it was acting up then just shut off wouldnt restart. after a couple mins sitting it would start and run for 15 seconds or so then turn back off. got back to the dock and wouldnt even start again. Tried hand choking it and no difference. Brought it home parked it went out tonight to test it and she fired up and was sounding beautifull again. So far i have replaced my fuel water seperator, my primer bulb, fuel pickup in the tank and cleaned the carbs a little with some carb cleaner. could this just be carb related. i bought a spark tester today and set the gap on it at about 1/2 inch and it fired cleanly across on every cylinder. ( i tested this back at the dock when it wouldnt start) im lost, hoping a veteran can chime in so i can get her running rite for the summer. Thanks in advance p.s. also replaced the spark plugs yesterday with the ones recommended for it the old ones were black and nasty and i replaced them around september.
