"the motor seems to be overhea
"the motor seems to be overheating as the temp horn comes on so i bought a new sensor because the old one seemed to be faulty and would come on around 165 degree's.motor has new head gasket's,water pump,and t stats.motor was sitting for a long time before i got and the carb's need to be redone i think cause it run's a lil ruff on idle and i haven't changed the poppet valve yet either.can someone please help with this.water comes ot of pisser good at idle and low rpm's bit the start's to fade a lil when you go over 3,000 rpm's and the horn comes on"
