I have a 1979 Wellcraft Suncruiser 225, Alpha 1; PO claims he swapped motor to a GM 350 Crate engine. Runs great, shifts into gear just fine. The problem is it won't shift back into neutral from drive or reverse. So when I pull the lever back to idle, I have to shut the engine off, then shift into neutral and restart engine. But again, it shifts INTO forward or reverse just fine, it just won't shift back into neutral with the engine running. After doing some extensive research its obvious the first thing to check is the shift interrupt switch. I have the boat at a shop right now having a mechanic look at it but I'm getting nervous that he doesn't fully understand what the interrupt switch does. Earlier today he said, "most people just remove those on these older boats". And, "its not functioning properly anyway because I can start your boat while its in gear (forward)". He thinks its the clutch dog in the lower gear assembly that's causing the problem and thinks I should replace the whole drive. Also, when I looked for the interrupt switch, it was strangely placed upside down, underneath the plate that usually holds it. I thought this was strange as all the pictures I've seen its always mounted on top so its accessible.
Any thoughts? I appreciate your time and thanks in advance for your response.
