Please help. I recently inherited a Boat with a Honda 130 4- stroke that has been setting up a few years 3-4. I drained the old fuel from the lines and the VST and attached a new tank of clean fuel to it. Could not get it to start. I changed the plugs and I did check spark, ok.
I have read many of the forums trying to figure out what to do next. I did check the voltage to the HP Pump. When ignition is turned on it goes well over 12 volts then sounds like a relay kicks it out. I can not hear the HP pump rev up. I am thinking this may be the problem. Can old fuel cause it to freeze up? What is the best way to check it?
