[h=3]Please advice on homemade dive plateform can I JB cold weld glue[/h]
by Steve the Brain » Mon Mar 13, 2017 6:40 am
I’ve bolted and revited diamondplate though the tube it stiffenes up the diamond plate.
I currentely have one triangle surport second isn’t pictured, even though the cut triangle is grinded smooth I’ll bend it over.
Will be bending a tube grab handle then bolt top to transome cap bottom bolts the plate.
Sinces it is already very sturdie curious if I can get away using I JB cold weld glue to smooth over inbetween plate and tube and probablley glue where I bend over the triangles?
designed this to hold a extra large cooler w/ around 200Lbs of fish ice, or a upto 19 gallon external fuel tank, will be used to hold catch retrial stuff when diving.
