Play on Lower Unit
E
edloh
Guest
Remove and inspected my lower
Remove and inspected my lower unit on a 1982 115HP Johnson and i am getting the following play
driveshaft - axial play (up/down) maybe a 1/16"
radial (side/side) 0.009"
prop shaft - axial play (in/out) maybe 1/8to3/16"
are these acceptable play? or i need to change the bearings?
remove the bearing housing and look at the bearing in them and they seem fine. but how can you tell the wear on needle bearings?
thank for any input from Joe or anyone else.
"Ed..... I wouldn't be con
"Ed..... I wouldn't be concerned about the driveshaft play. The 3/16" propshaft play is a little much and could be contributed to a slightly worn thrust washer and/or bearing. However, If that lower unit has been shifting okay and is not leaking... in effect has been operating fine, I'd wait until a problem develops before tearing it down.
Joe
