niterider64
Hope someone can help, I have searched but did not find my same problem. I have a 1996 Rinker Captiva w/ a merc 454 mated to a bravo 1 o/d w/ power steering. My steering has always been tight then all at once there was about 1/2 turn on the wheel before the o/d turned. I found the sloop in the tube that the steering cable threads to. This tube slides left to right about 1 inch within the power steering unit actuator. There is a small set screw at the 12 o clock pos. that is tight and a gland type nut w/ holes around the circumference that is also tight. I do not see any type of jam nuts to hold this tube/ guide within the p/s assy. The sloop is not something that has been wearing over time, something just let loose. On another note, I never used to be able to turn the steering wheel by pushing on the o/d, it was solid, now I can easily push the o/d from stop to stop. Any help would be appreciated.
