Plastic tube in crankcase
joe_arena
When changing oil on a 2004 ho
When changing oil on a 2004 honda bf50 I used an electric pump with a plastic tube that inserts into the oil dipstic tube. After pumping out the oil the tube was being removed and got stuck . I tugged on it and got it free but the end of the tube had a diagonal slice removed. The piece is about 1 1/2 inches long and 1/4 inch wide.I replaced the oil and filter and ran the engine.It seems fine .Its difficult to pull the boat out of the water but when I do I will drain the engine oil from the bottom drain. What should I do ?
