Hello All,
First timer to the forum. I've spent the last hour reading all the posts on removing the philips pivot pin on the lower unit. I did it last fall when I thought I was draining the oil. Here's the weird thing, I removed it and it went right back into the lower unit. This spring, I decided to look into what this screw was for and saw in the manual that I shouldn't remove it. Now that I know what it is, and that it is back in place, everything seems to shift okay.
How will I know that something isn't right? Would it shift at all? Is there a way to test it to make sure everything is still lined up? I don't want to take the screw back out and check if the hole is lined up.
Any help is greatly appreciated. We're ready to hit the water, but thought I better check on this first.
Marty
Marty
