My 1977 25 HP manual start Evinrude has a deep pit in both piston faces. I discovered this while trying to determine if my engine died at idle because of lack of fuel or flooding. There is one pit at about 10 o clock on both pistons when viewed thru the plug hole. They are about 3/16 bi 1/16+ deep. Top 1 is bright-bottom is carboned.
History: The engine has not started or run at idle well for a short time then it just refused to start. I soon found there was no spark. After testing all I could I installed a new Power Pack and it started but immediately died. It then was extremely hard to start again. I have cleaned the carb 3 times to include high pressure H2O and probing with soft wire. All passages seemed clear to include fuel holes in top of carb throat. New bowl and H. speed nozzle gaskets were installed as well as S. speed needle packing [new style]. Float set at parallel to carb base. Slow speed needle set 1 1/2 T out. I also tried at 3 full turns out w/ no change. New fuel lines and bulb and F. Pump screen. Gas line disconnected at carb and rope pulled pulses gas out. New bulb delivers gas well and the gas tank is clean. There is no leakage at the fittings. I installed 2 new Champion L77JCH plugs gapped at 30 T. New non ethanol gas at 50:1 in a clean tank.
When I took the slow speed needle out I noticed about 20% of the packing was missing. There were 3 pieces still in the threaded portion of the Carb despite having removed the needle !!!!I washed this out by inserting the straw of a can of carb cleaner past the debris to insure I didn't force it deeper. I probed the idle holes in the top of the Carb throat as well as the slow speed tube extending upward from the bowl. Carb cleaner seemed to pass these areas well after that.
Compression is 98 and 100 psi. I believe the T stat works properly as the engine warmed quickly on muffs and yet I could hold my hand on the top of the head and crank case w/ slight discomfort. I had to run at more than a fast idle to keep it running. It emitted a lot of white smoke which I assume included steam as it was in the 50 degree range.
The plugs show no evidence of touching the piston and the pits are not centered where I assume the gap would be. What is I my problem??? Bill
