Piston hit compression tester adapter....
cjbrill715
The adapter was brass, and it left a crescent/fingernail clipping shaped dent in the crown of my pistons....It's a 25 hp evinrude, and it didn't break or flake anything off in the adapter into the cylinder, it just left a flat spot on the end of the adapter....My question is, will this hurt anything, or should i just run it??
I assume that "adapter" is threaded... and if so, apparently it's longer that the threaded & electrode portion of the spark plug?
How did you do a compression test if it hit the piston? If your compression tester hit the piston hard enough to make a dent, doubtful you could have pulled the motor over.
Yes, threaded brass adapter. cheap $30 one from autozone. I should have took a closer look at it before using it. The piston hit the adapter piece at the edge/end of the threads, and left a diagonal flat spot on the adapter. It screwed out harder than normal, which was my first clue, but didn't appear to flake off any material....I took it out this morning, boat ran fine, my question is, is this something to be concerned about??...It left a crescent shaped dent in the crown of the piston...
It screwed out noticeably harder than it went in, the adapter's threads where hammered over on the end/corner of the adapter. I shined a flash light in the bore, and saw a crescent shaped ding in the piston crown. My guess is the brass was soft enough to give before locking the crank out, but hard enough to dent the piston....Boat ran fine today, and compression still looks good...Just wondering whether to worry about it or not??
