Piston change
txny13
"shold i change all pistons wi
"shold i change all pistons with new ones or just change the 4 that are bad i found some used ones over at trobo brick,cheap"
"today i did some work on them
"today i did some work on them piston now i know i have24mm wrist pinsand that they are89mm pistons in the d,s"
"What was the original problem
"What was the original problem? Why are you changing pistons?
If it was a bearing spun making a rod knock, you need to look at the crank....
What's the deal? Fill me in."
