electric mike
Hey all,
My marine Perkins 4.108 has been overheating. Gets up to 230/240 after 15 minutes of running.
Here's what I've done already:
Here's a diagram I drew up of my cooling system:
- Replaced diesel fuel, added additive
- Fuel filter change
- Oil & filter change
- Replaced water/exhaust mixer, was rusted and inhibited raw water flow. Raw water flow is great now
- Removed, disassembled, and flushed out heat exchanger
- Checked all coolant hoses for clogs and damage, replaced a few bad ones
- Opened what I thought was the thermostat housing, but there was no thermostat inside
- Engine coolant is a milky yellow color
- Replaced coolant pump impeller
- Previous impeller had broken inside the pump
- 8 of the fins had broken off
- Recovered 2 fins from inside the pump
- 6 fins still missing somewhere inside the system
- Completely drain and replace coolant
- Replace gearbox oil filter
- Check gearbox oil filter for missing impeller fins
- Find the 6 missing impeller fins
