Hi guys,
I have the boat with a Penta D3-130 diesel and Penta EVC system.
The trim pump had a wiring change at least in part with the pump control relays.
Probably everything was properly folded, but over time some cables fell out of the "sockets".
Now I have the working boat with EVC system reporting two alarms associated with trim up and down control (causing reduced power) and two cables with which I don't know what to do.
Alarms:
There're two not connected cables: 1.white with a blue stripe and second one - white with a green stripe. Both are in one tube described "TO TRIM PUMP CONTROL"
From the service manual I know it comes from C2 socket in the EVC system.
I have a troubleshooting procedure from service manual but the cables from the pump control relays (shifter up/down - relays) were changed to non-original ones. In addition, the system works normally except reported errors limiting engine power.
So the main question is where is the "PUMP CONTROL" and what does it mean? How to connect this two wires?
All cables at the pump relays are connected (installation reworked).
Small green and blue wires are going from the shifter (up/down).
EVC reported also another problem:
The problem was resolved by reconnecting the cables from the trim sender (the original connections have been replaced with a connection block which has loosened).
Perhaps these cables should be connected nearby the relays to the cables with the signal from the shifter (small blue and green)?
or with a trim sender cables as a bypass of the ECV system?
The oryginal cable with relay-s look like this (from google):
You can see that one of the cables is described "To trim pump control".
I attach photos and a fragment of the service manual.
View attachment trim2.pdf
Alarms:
| MID 140, PSID 30 | FMI 4 | Powertrim motor direction up |
| MID 140, PSID 31 | FMI 4 | Powertrim motor direction down |
| MID 140, PPID 290 | FMI 3 | Powertrim signal or supply |
